I am using ffmpegx 0.0.9x.
running 10.3.9/ 1ghz titanium
Up until about one day ago it was working fine.
Video renders fine, but the audio runs at 10times the speed.
I've run audio (without video) through ffmpegx and it all encodes at high speed.
I havent changed any settings, and I've tested the rendering against other programs such as MPEG streamclip (the audio and video are in sync on the other programs).
I would hate to render video by itself, then encode audio down and then mux them together. It would be great to have the old ffmegx back to do it in one shot !
Any thoughts would be helpful ?
I don't believe the audio is in mono...
from two hours of footage and audio - video plays two hours and the audio might take about seven minutes to play.
Would it matter if the audio is muxed or seperated and then compressed through FFMPEGX ?
It does compress with out issue in other programs ?
—I think I also have the same problem. I have an AVI file that I first burned it to DVD using Toast 7. The video looks fine, but the audio would stutter and skips.
—So I thought, maybe I should use ffmpgX to conver the AVI file to DVD. And this time, the audio sounds like chipmunk. And the orginal AVI does say “monaural” (does this mean it’s only 1 channel instead of stereo?)
—What can I do to solve this audio problem?
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
