I have ripped a vob file using DVD Decrypter, and it plays ok in Nero Showtime.
I used Super and Videora iPod Converter, and the video is OK, but the audio seems speeded up (or high pitched - as it is not shorter than the video).
I dont understand why. Has anyone else had this problem?
Is the audio in sync with the video? Did you do any framerate conversions like NTSC<>PAL? Check the framerate of the original to the final product. Gspot 2.60 should be able to do that. You can adjust the pitch with a audio editor like the freeware Audacity, but you need to fix any sync problems first.
The audio seems to be in sync.
I didn't do any other conversion other than use super and videora (separately) to try and convert the vob to mp4.
Could there be something about the vob that is causing a problem with the encoder. Should I try to convert the VOB to mpeg 2 or something?
Converted video (mp4): audio out of sync
By darknezx in forum Video ConversionReplies: 4Last Post: 22nd Mar 2011, 02:25 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32 -
Youtube MP4 Videos Converted to AVI Have Out-of-Sync Audio
By ConverterCrazy in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 16:31 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 19:39 -
Problem with .dv file that I converted from .vob for iDVD
By eric56 in forum MacReplies: 7Last Post: 9th Jul 2007, 03:25
