Can you help, i want to burn a film that is in avi file on my hdd through ashampoo. At first i converted it to iso than burned it through ashampoo then when i tried to play it on my dvd player it said wrong disc.
I've look at all the things on ashompoo but don't seem to be able to bur a disc that will play on my dvd player.
Thanks.
a) why is thi sin the VCD section ? Do you want a VCD or a DVD ?
b) just burning an avi to a disc won't make it play unless your DVD player will play avi files, and it is in the correct format to be played
c) have you searched the guides and tools sections here ? There are dozens of programs that convert video to VCD or DVD for standalone players.Read my blog here.
Sorry for putting this in the wrong section.
I want it in DVD i was told that ashampoo was the best burning tool.
I've put it through nero witch seem to take ages and got a error message near the end of burn.
So i converted it to VIDE-TS so i could put it through dvd shrink and i got an error at the end of the burn as well, so i thought I'd try to put it through ashampoo.
Would the film being to long have anything to do with it but i was told it would not make any difference.
Thanks.
Once again sorry for posting it in the wrong tread. -
How did you create the Video_TS folder ?
What errors did you get ?
DVD shrink does not burn by itself. It uses either Nero or DVD Decrypter to burn. If Nero failed on it's own, chances are Shrink tried to use it as well, and it failed again. The error messages might tell us why.Read my blog here.
Ashampoo Burning Studio 9 problems
By Mike_EH in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2010, 19:21 -
By Jamie2939 in forum DVD RippingReplies: 5Last Post: 20th Apr 2010, 11:54 -
By kenmo in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2009, 21:56 -
mkv -> DVD with menus (ashampoo burning studio 9) not working.
By Substance001 in forum Video ConversionReplies: 3Last Post: 29th Sep 2009, 05:55 -
Nero To Ashampoo
By marioval in forum MediaReplies: 7Last Post: 30th Mar 2008, 07:58
