Hi folks!
Please help me if you can!
I have a winfast pvr2000 tv tuner. If I choose Adaptive Channel Scanning from its software the tuner scans and founds all the channels very nicely. However if I restart the winfast pvr software the screen looks like before channel scanning. If I take a look on the list of channels everything looks OK (the list also contains frequency values for each channel). However if I select any channel from the list, the screen is like mentioned above.
This Adaptive Channel Scanning used to be working in the past.
If I select a region then everything is OK on restart, however the list of channels is not complete in this case.
Any ideas?![]()
Thanks a lot!
Are you running the latest version of the PVR application ?
You can find it here : ftp://ftp.leadtek.com.tw/tv_tuner/WinFast_PVR/application/061117/WinFastPVR3112.zipRead my blog here.
I've tried 2 or 3 versions of the PVR software including the one indicated by you. I've also tried several driver versions.
There is this, as yet unreleased version here : http://tw1965.myweb.hinet.net/WinFastPVR2.htm
Read my blog here.
I've already found the Winfast PVR2 software. This version solves this problem, but it has a disadvantage.
Channels in the upper frequency range (above 300 MHz) doesn't have sound or the sound is very noisy.
I don't know if this comes from the fact that my cable television provider uses both B/G D/K mode
hdtv tuner for over the air channels
By carlos28355 in forum DVB / IPTVReplies: 7Last Post: 21st Jun 2010, 18:07 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 14:46 -
Best tv tuner chipset just for getting channels best
By blitter2 in forum Capturing and VCRReplies: 0Last Post: 26th Dec 2008, 08:01 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 12:13
