Ok I've searched and searched and found very little info on my problem, and not a single topic on these forums.
Basically, Premiere Pro 2.0 doesn't launch on my 32bit Business Vista... No error message, just the splash screen and then it shuts down. I've tried running it in compatibility mode and it's still the same. I have the latest ffdshow, latest video drivers... I don't know what else to do ;(
Any help appreciated.
That might be the problem. Next time you try to launch Premiere, pay very close attention to the text that it displays in the splash screen as it loads each module. I can't remember the exact name, but if it disappears at "Loading Vfw<something>", it's likely because of problems between Premiere and your installed VfW codecs.Originally Posted by bledking
We sell a DV decoder that comes in both Vfw and DirectShow flavors. With the VfW version installed, Premiere (1.5 and Elements) would behave the way you described. The problem lies in Adobe's software. It doesn't honor the information that comes back to it when querying codecs about their capabilities. This has existed for years - at least as far back as Premiere 4.0. We had to rewrite some of our code to accommodate Premiere's broken code....
The simple test for this theory is to uninstall ffdshow and see if Premiere launches successfully.
My understanding is that Premiere Pro 2.0 does run on Vista.John Miller -
It just says:
v2.0
Windows NT6.0, Single Processor detected
Initializing Application...
And then shuts down, no clue there. Is there a crash log or something like that ?
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Premiere Pro 2.0 vs. Vista
By newsphotog in forum Newbie / General discussionsReplies: 5Last Post: 6th May 2008, 18:09
