Hello all,
i have a minidvd video_ts directory which seems to have some files missing (or deleted) and
structure is corrupted , is there a way to repair again so i can burn and watch on dvd player
thank you
Results 1 to 9 of 9
maybe this will work
copy the video_ts to your PC
rename the vob files to mpeg
example vts_1-01.vob to vts_1_01.mpeg
they should play with your video player program, and you can edit them ( if needed ) with your favorite mpeg editor
check them with video inspector to find the aspect ratio, bitrate, frame rate, and resolution, youill want that info when you author the DVD
now load those files into your authoring program, convertX or other choice , check your bitrate, and FPS, aspect settings, and click the button to author/convert the video, when its done burn to DVD with your favorite burning program -
What is missing? If it's only some BUP file, you can just copy the corresponding .IFO file, and rename the copy to .BUP
/Mats -
i always thought it was the other wayOriginally Posted by mats.hogberg
the bup is the backup for IFO of the same number if its corrupted or the disc is damaged and the ifo can't be read, isn't the DVD player supposed to automatically read the bup ( if its there ) if it can't read the IFO
he did say mni DVD from camcorder, isn't that the same file system as a DVD recorder with an RM folder which contains the edit tags,
its been my situation where if that is corrupted, there is NO backup and the DVD doesn't play -
Well, it works both ways, as aOriginally Posted by theewizard
x.bup=x.ifo, which implies that x.ifo=x.bup. If you have one (but lack the other) it can always be fixed with simple file copy and rename.
/Mats -
yes, but does a DVD have to have both copies of those files in order to be playableOriginally Posted by mats.hogberg
does the player check one against the other, I thought the idea was 'either OR'
that if the info was bad the player looked for the BUP file and would play the disc as long as one of each number was correct
but we are getting away from the OP's problem -
As an experiment, I deleted all the bup files in a VIDEO_TS set and burned it. Played fine.Originally Posted by theewizard
The idea of a backup is to halve the chance of failure, not double it.
As for the OP, if he has all the VOBs, they can be converted back to ordinary MPEGs and reauthored.
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 08:54 -
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 13:43 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 20:40 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47 -
VIDEO_TS to mpg to VIDEO_TS
By Mållgan in forum EditingReplies: 9Last Post: 29th Jan 2008, 15:53
