I converted my avi into an mpeg 2 with HCEnc and i demuxed the audio using VirtualDubMod. I then converted the audio to AC3 using AftenGUI. I also used AC3Gain posted by a member of the forum to increase the volume of the sound. When i muxed eveything using MuxMAn, the sound plays 7-8 seconds before the video. I tried using the time delay but i couldnt get it properly.
What should i do?
Thanks!
Thanks mate! It worked! But why did it happen in the first place?
I think i might have made a mistake while converting with AftenGUI.
I just converted with the default settings i.e CBR mode 384 kbps. Can you specify the settings to be used? The source AVI has no such Audio problem. -
Very hard to tell for sure. Sampling rate of the audio can have an impact, skipped video frames, many issues can be at fault.
problem with Muxman Audio
By ramimahafza in forum Authoring (DVD)Replies: 1Last Post: 26th Jun 2011, 00:38 -
MuxMan 0.16.7 will not open AC3 audio file.
By Nagashi in forum AudioReplies: 9Last Post: 27th Jul 2010, 10:29 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 11:23 -
Editing Audio on a DVD and re-encoding (muxman gives an error)
By Hulkmanche in forum Authoring (DVD)Replies: 6Last Post: 23rd Apr 2009, 02:21 -
Audio out of sync, Batch DVD Steam Converter & Muxman
By assman24 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2008, 16:25
