Ive just Installed lsx mpeg encoder but when i open a file i get an error message come up abouut the audio compressionaying unsupported format or compression type,anyone know how to get round this thanks
Hello
You are trying to open a DivX file that means that the audio is MP3 and not wav that is supported by lsx mpeg encoder..... first u have to change the file to wav and not mp3.... you can do this with avi2mpg (avi2vcd) and select the Decoder exe something.... Good Luck -
Just to save you the hassle of going to Ligo I had the same problem. My problem had to do with AVI type 1 versus Type 2 files. Here is the response I got from Ligo:
We use Microsoft Video for Windows in the standalone encoder to decode the AVI file during the encoding process and VfW only supports Type 2 DV-AVI files.
The DV-AVI format comes in 2 types, type 1 and type 2. Type 1 is a DirectShow ONLY based format which is not VfW compatible. Type 2 is a DirectShow and VfW compatible format so if a Type 2 DV codec is installed on the system our encoder can usually open and encode these types of files. Most digital camcorder capturing software will allow the user to select either type 1 or type 2. If not there are a couple of 3rd party DV codecs that are available. We usually recommend the MainConcept DV codec (www.mainconcept.com). Adaptec also has a DV codec called DVDeck that is designed for their hardware but can be installed without it.
Most video editing applications support the standard Microsoft AVI format which we recommend to be uncompressed or RAW for the best quality encoding.
Thanks,
Cliff Chupp, Technical Support
Ligos Corporation
My DV editor VideoWave converts my captures to the wrong type (type 1) and I can't use the Ligo encoder so I gave up after trying several things. It just wasn't worth the effort for an average encoder.
TMPEGEnc work fine, however, on these files. Good luckPIV-2.4G ASUS MB, 1G Mem, WinXP
Playing a clip every 15 mins
By christian_j in forum Video Streaming DownloadingReplies: 0Last Post: 6th May 2010, 13:30 -
MKV, 1:37 long, audio always comes out 44 mins only..
By TheGlow in forum Video ConversionReplies: 6Last Post: 20th Apr 2009, 16:45 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
Youtube 10 mins 59 secs?
By nam207 in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 23:24 -
MPEG_Streamclip - Only Exporting 1.33 mins ?
By 12Quidkidinnit in forum Video ConversionReplies: 0Last Post: 23rd Jul 2007, 08:26
