Basically what I want to do is, in a short video, play each frame twice, yet keep the same frame rate so that the video looks like it is in slow motion. I'd like to do this in VirtualDub, so if anybody has any help, or can tell me what filters to use, that would be great.
Tim
In the top of the Frame Rate dialog select the "Change to" option and set the frame rate to half the original.
In the middle section select "Convert to fps" and set the original frame rate.
You're audio will be out of sync of course.
If you just want a file that plays at half speed on the computer you can use a program like AVIFrate to change the frame rate (it's just a value in the header of the AVI file) without reencoding.
Slow motion videos- how to create some sections
By doggieusa in forum EditingReplies: 3Last Post: 10th Dec 2012, 19:42 -
Urgent: how to make a photo effect zooming in and out in slow motion
By bototucuxi in forum EditingReplies: 5Last Post: 4th Jun 2011, 01:46 -
best speed to shoot to get slight slow-motion effect in music video?
By Cumie Music in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2010, 00:58 -
Slow Motion Effect
By leedownen in forum Video ConversionReplies: 5Last Post: 13th Feb 2008, 02:16 -
Creating this specific slow-mo effect.
By rjwise in forum EditingReplies: 2Last Post: 19th Sep 2007, 04:04
