Under the quality settings tab in DVD Shrink you can choose the adaptive error compensation (AEC) option. You have the option of - Maximum Smoothness, Smooth, Sharp(default) and Maximum Sharpness. So which one is the best to use? And does enabling this option (which I have never done) really make that much of a difference in picture quality?
I always use the "smooth" option. Why? I would rather have a picture with less detail if it means less compression artifacts.
Although I hardly ever use DVD Shrink these days and if I do I try to use it with no more than 85 - 90 percent compression (or 10 - 15 percent reduction).
If I need to compress more than that then I use DVD Rebuilder or sometimes I re-encode the main movie and put it in my own simple TMPGEnc DVD Author produced menu.
I find with a lot of movies these days ... if you use VobBlanker to remove the extras and the languages you don't need (i.e., just keep the 5.1 DD track) ... then use MenuEdit to "fix" the menu of the things deleted with VobBlanker ... you often are left with something that will either fit onto a single layer DVD disc and if you do need to compress then DVD Shrink usually can be used since the required amount of shrinkage needed is usually very small.
However even if only doing a bit of Shrinkage with DVD Shrink I still use the "smooth" setting.
- John "FulciLives" Coleman
P.S.
When I do use DVD Shrink I only use it on the main movie and other videos (if there is like a making of and I want to include it etc.) but I never use it on the menus. I heard that this might cause issues. Not sure how true that is."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Ditto Fulci.
All transcoders I'm aware of (with the exception of Instant Copy) work like this:
http://forum.doom9.org/showthread.php?&threadid=63587
Since you must lose DCT precision data (error correction), it seems to me sharp would accentuate jerkiness under "heavy compression". The term is necessarily vague, as the source file bitrate has a lot to do with how much "compression" is tolerable. Also, whether it's talking head or action, etc. My own rule of thumb is Shrink at default for single-digit reduction (again, depending), and DVDRB otherwise. YMMV.
Pull! Bang! Darn!
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
DVD to MP4 conversion playback not quite smooth.
By scottb721 in forum Video ConversionReplies: 1Last Post: 21st Jun 2010, 10:45 -
Can't interface Panasonic DMR-15 DVD Recorder with Sharp LC-42D65U HDTV
By fideauxdon in forum DVD & Blu-ray RecordersReplies: 3Last Post: 2nd Mar 2010, 16:15 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 18:23 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
