I have encountered this problem more than once. Sometimes when im reformatting, and im booting from the cd/dvd drive, ill get so far in the xp install and the install will then stop and tell me that a certain file cannot be copied and i must either retry by pressing enter or exit installation by pressing escape. It goes on to tell me that xp may not work without this file. Any way, i press enter a few times and i go back to that same screen, finally i open the drive theh close it immediately then press enter and itll start to copy the files that were once uncopyable. This happens a few times during the installation process and takes forever to format. During this time i notice that the drive will act as if its not doing anything, and just sit their quietly, even though the computer is on, and there doesnt seem to be a problem with the hd, because i transferred it to another comp and the sata drive is working perfectly. This keeps on happening and i have yet to format this comp. Mind you, i also tried using two discs, everytime the message pops up, put in the other one and try again, but at the end of that, i guess one disc was older than the first (the original had sp2 preinstalled on it), and when i finished, it told me that some components may not work....WHAT SHOULD I DO...HOLLA BACK ASAP
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
This is a legit M$ disc?
I have actually had to interface (using a USB cable thing) and format a HDD the hard way from my laptop - before I could get a clean install of windows. As a matter of fact: If I do any installs anymore, that is exactly my procedure, irreguardless of Windows version. I first noticed this problem with (a legit copy of) Windows 2000 a few years back. It seemed the method of letting the MS cd do the format just didn't get the drive clean enough.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
it seems it is looking for a file it can't read , maybe disc is scratched or dirty. Clean the disc or make another one with integrity check
This is a legit disc, so your saying i should use someother device to format the drive first...how bout i stick it in my other comp and format it from their....holla back
Its a brand new xp disc...no need to clean
Possible problems:
Bad CD/DVD Drive
Bad IDE cable on the cd/dvd drive and/or the HDD
Bad Ramm
Overclocked CPU -
I've had this happen a few times. The first time it was a dirty disc and the second time a flacky cdrom drive. Changing the drive corrected the issue.
Google is your Friend
I have a blank screen when booting
By edong in forum ComputerReplies: 4Last Post: 17th May 2010, 00:19 -
booting problems
By romanstopme in forum ComputerReplies: 11Last Post: 8th Sep 2009, 14:58 -
No booting on a 4 year old emachine
By yoda313 in forum ComputerReplies: 38Last Post: 5th Nov 2008, 14:43 -
New PSU and system not booting it seems...
By doublelayer in forum ComputerReplies: 5Last Post: 18th Jun 2008, 14:21 -
Booting issue ... PC problem!!
By Lucifers_Ghost in forum ComputerReplies: 35Last Post: 14th Jan 2008, 18:17
