I have a school project in which I would like to combine a few different movie scenes from one DVD movie. I was able to de-author DVD.
Is there software that can 1) cut and 2) combine scenes together from a DVD disk or from VOB/IFO files? Commercial stuff is fine too.
@ jamesdin,
Didn't you post this same? already?? any way, use shrink in re-author mode.... for free
http://www.dvdshrink.info/compilation.php , or commercial (not free) ,
ConvertXtoDVD , DVDremakePro. look to the left under lists for various tools.....good luck!!!" Who needs Google, my wife knows everything" -
In reauthor mode it can be used to isolate sections of a disc (drag the title to the lefthand pane, right-click and select Set Start and End Points), bring different parts from different discs together (open the different discs and drag the parts you want to the lefthand pane), then restructure this into a new DVD.
Caveats :
1. No menus. You loose all menus in reauthor mode, and Shrink doesn't create new ones.
2. Every clip will be a separate title, so no smooth playback across clips or chapter hopping.Read my blog here.
Short answer yes...but as guns. said no menus.. However you can add menu after ,but thats a diff. subject, you may not want to deal with at this time IMO.. For your school project it may work just fine though .I've used this method several times and it plays fine.Originally Posted by jamesdin
you can also use Nero express and create menu and add video files, save and burn to disk....." Who needs Google, my wife knows everything"
Newbie Conversion questions: combine multiple .m2ts files
By Deku Scrub in forum Blu-ray RippingReplies: 10Last Post: 30th Aug 2013, 19:58 -
Cut clips from home DVDs and combine them with Pinnacle
By avz10 in forum EditingReplies: 9Last Post: 6th Feb 2010, 16:06 -
Final cut express simple question
By thecrock in forum MacReplies: 1Last Post: 17th Apr 2009, 11:48 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 08:02 -
final cut express HD... quick question
By ednarophati in forum MacReplies: 1Last Post: 10th Jul 2007, 11:32
