I have a divx 6.0 mpg4/mp3 file that is encoded in pal (25fps). I need to convert it to an NTSC DVD. I have access to almost all software on the mac so dont hesitate to recommend a product that will do the coversion.
Will a 2:3 pulldown work just like it does converting film to ntsc?
Results 1 to 11 of 11
Check out this post.
I haven't had good results with applying a pulldown to PAL sources. I get better results going from 25fps to 29.97fps. -
Make sure you really need to convert at all. Most DVD players will play both. Strictly speaking the NTSC DVD standard requires Dolby audio (as distinct from MPEG audio) but that's loosely applied these days.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
Thank you for the suggestions, I will let you guys know how it works in a few days.
What method did you end up using?
Paul May
Spotmen Studios Inc.
15 N. Arlington Heights Rd.
Suite #103
Arlington Heights, IL. 60004
spotmen.com
http://spotmen.com/search/spotmen.html -
Originally Posted by ArtemisG3
Originally Posted by tomlee59
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 02:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 23rd Jan 2008, 23:13 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 12:13
