Canopus MTV2000
Look ever better then old MTV1000 my guest you will be able buy it unless you live in Janpan.
How ever this one got some really cool features
High picture quality efficiency in wide circumstance showing
3d Y/C separation and 3d noise reduction, the time based collector, the high functional front ended * digital signal processor " Triple 3d Video Processor " which has the function of automatic gain control and, influence of the ghost is lightened loads " due sir 10Tap digital ghost Lee ". It is possible to prevent influence such as noise and the extension of the tape which become cause of the indication which decreases the efficiency of MPEG2 compression and/or is warped.
When of 3d Y/C separated ON
When of 3d Y/C separated OFF
TV reception section
NTSC (the Japanese region correspondence)
Audio multiplex / stereophonic broadcasting correspondence
Reception possible channel VHF 1 - 12, UHF 13 - 62, CATV C13 - C63
(It cannot receive the CATV where the private receiver and the like becomes necessary)
Video input section
Video input signal NTSC
Video input terminal 7 pin mini- DIN connectors X 1
(The S video cable can be connected, the composite video cable can be connected or with the pin-jack conversion cable of attachment)
Input image adjustment The Brightness, the Contrast, the Hue, the Saturation and the Sharpness are reflected adjustment possibly & encoding result.
Overlay indication TV reception image, video input image and playback image in PC picture overlay indicatory possibility
(There is no video signal output function)
The display hardware and the display driver, have the necessity to support the overlay function of DirectX 5 or more. In addition, depending upon the type and indicatory resolution of motherboard which is used and the setting et cetera of refreshment rate there are also times when you cannot use.
Overlay image adjustment Brightness, Contrast and Saturation adjustment possibility
* It is reflected on the encoding result
Audio input/output section
Audio input RCA pin jack (red / white)
Input impedance 22k Omega (typ)
Full scale input level 2vrms
Audio output 3.5 Phi Stereo mini- jack or connector for connection inside sound card (audio cable of attachment use)
* To connect both simultaneously, it does
Conformity load impedance 10k Omega or more
Full scale output level 2vrms
Sampling frequency 32kHz, 44.1kHz and 48kHz
Data width 16 bit
MPEG encoding section
Video compression ISO/IEC 13818-2 (MPEG2)
ISO/IEC 11172-2 (MPEG1)
Profile level at time of MPEG2 MP@ML, MP@LL and SP@ML
Video pixel number 720x480 (Standard)
352x480 (Half)
352x240 (SIF)
Video bit rate MPEG2 Standard 4m - 15m bit / second
MPEG2 Half D1/SIF 2m - 8m bit / second
MPEG1 SIF 1m - 1.8m bit / second
GOP constitution IBBP
I frame only
Audio compression The ISO/IEC 11172-3 the Layer 2 (the real time compression with the software)
There is no compression (the WAVE file by the linear PCM compilation)
Audio bit rate 128k, 160k, 192k, 224k, 256k, 320k, 384k bit / second
Multiplexing When the ISO/IEC 13818-1 the MPEG2 program stream (sound is the linear PCM, it cannot multiplex)
When the ISO/IEC 11172-1 the MPEG1 system stream (sound is the linear PCM, it cannot multiplex)
There is no multiplexing (each file of video and audio compilation)
Other Features
TV Scheduler
Time-Shift Recording
Channel surfing
Still picture
VideoGate 1000 on-the-fly * preview actualization
Audio (sound recording of playback * WAVE)
Video (MPEG2 playback * other video playbacks)
Disk playback (DVD/VIDEOCD and audio CD)
Album playback
DVD-VR direct record corresponding software "DVD-MOVIEAlbum for Canopus"
DV -> MPEG2 file converter bundled
It does look like a nice card.
Do you think it uses the panasonic encoder the same as the MTV1000.
They have'nt posted their drivers yet so I couldn't check.
It would have been good if they added a hardware audio compressor but It does look good
Cheers
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26 -
Hot shoe pinout
By danno78 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Mar 2009, 12:19 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
