I have a Panasonic DMR-HS2, which allows either PCM audio or Dolby Digital on XP recordings. As PCM file sizes are much larger, does anyone know if the recorder compensates by reducing the video bit-rate?
There might be a slight lowering of the video bit rate, but there is room for the highest video bit rate and PCM audio on a 1-hour DVD so my guess is the video won't be any different either way.
I don't know about newer recorders, but on the older ones you could set the preference to audio or video, the manual saying the video quality would be compromised if set to audio.
PCM audio on BluRay
By ecc in forum AudioReplies: 2Last Post: 21st Jan 2010, 08:37 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 15:46 -
Vob2mpg PCM audio
By schematic2 in forum DVD RippingReplies: 3Last Post: 24th Feb 2009, 11:33 -
is LPCM the same as PCM, for audio?
By runLoganrun in forum Newbie / General discussionsReplies: 14Last Post: 6th Dec 2008, 19:37 -
PCM audio in MENCODER
By zepperdude in forum AudioReplies: 1Last Post: 16th Oct 2008, 21:56
