I have this short movie clip which is in .mpg format which i converted to .3gp for my mobile but its now 17mb is there a program to make this file smaller to use on my mobile
Results 1 to 11 of 11
can no 1 here help on this please as i am sure there must be some program to shrink this down
You are in breach of the forum rules and are being issued with a formal warning. PLEASE wait some days before you bump a topic. Not 2 hours.
/ Moderator Baldrick -
Not a by adding another program (which did you use in the first place?), but by using a lower video (and perhaps even audio) bitrate when you encode to 3gp, you'll get a smaller file - simple as that. Try 3gp converter. Most problems are solved by using the right app right, not by adding more apps to the process.
/Mats -
I used ImToo mpeg encoder but will try what u suggested and let u know if it will shrink it smaller
well I tried 3gp converter movie was as .mpeg and 140mb after using 3gp converter it made it 20mb which is still too big for a mobile
What do you mean by short clip? if you have ashort 20min clip it will have a "big" file size even in3gp
I love it when a plan comes together! -
As mats stated in his response, if you lower the video bitrate and perhaps audio as well, you'll have a smaller file size when you encode......Originally Posted by ricardouk" Who needs Google, my wife knows everything"
what do i use to lower video and audio bitrate will it show this in .3gp converter
ok I can see where it shows how to lower video and audio bitrate the file is .mpeg and now when i try and convert to .3gp all it says now is fail cannot understand this as it worked b4
How can i make subtitle bigger or smaller (SUP File Format)
By Charmer in forum SubtitleReplies: 9Last Post: 2nd Jun 2009, 15:43 -
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 05:35 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 23:57 -
How to make an audio file smaller?
By aruwin in forum AudioReplies: 13Last Post: 29th Jun 2007, 23:01
