Another problem!!!
I have a menu on VMG. From here, I must select audio track and then I can Play Movie. So, in this menu we have 3 buttons:
1. Select Dolby Digital Track;
2. Select DTS Track;
3. Play;
4. Goto Main
Now, if I apply the select audio command on buttons 1 and 2, when I play movie (with button 3), he plays the movie with the first audio track. If I select the 2nd track, I ear always the first track.
How can I resolve this problem?
ThankS too Much!!!
Try setting the audio from the VTS Domain (not the VMGM Domain).
Regards,
George -
Go to this forum. I am sure someone will explain how to do it.
http://www.mmbforums.com/phpbb/viewforum.php?f=24
There is also help file which talks about how to make menu for different combinations of language and movie selections.
http://www.mediachance.com/dvdlab/helppro2/index.html
I also red your other post where you are asking about 20 VTS's.
If this is related than your project does not have to use WMG, since this is usually used if you have more tan one VTS to navigate between them. Even for this DVD Lab has a "BRIDGE" icon which can be used to go from one VTS to other.
On top of this all pro DVD have audio (PGC) direction in the VTS where the movie is.
Error Message when selecting a movie in VTS
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Sep 2011, 15:08 -
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 12:54 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 09:52 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 18:10
