anyone know how to get this off my pc..it says go to the site and this pop up will disapear..please anyone help none on my malware scanner has been able to find this..
software is a scam.
this program may help.
http://www.download.com/HijackThis/3000-8022_4-10379544.html
program is not noob friendly
scan and save the log and post it here to analyze it
http://www.hijackthis.de/
next time use CCleaner registry scanner and cleaner
http://www.filehippo.com/download_ccleaner/ -
Your computer went somewhere and downloaded a program that is a ... no no.
Now you need to do a search on the Internet for the fix.
Spy Emergency 2005 ... might help you ... this is the one I use ... just incase I catch something I dont want.
Sometimes I have to reboot to remove the program ... in question. -
the only program I know of that was downloaded..was a program from suddenlink that switches email address..from where we are converting from charter to suddenlink..and from a game named silent hunter3
It comes through the Windows Alert Service. You didn't d/l anything, what has happned is your IP address (or is it DNS - I forget) is being targeted by a mass spammer.
You can report the problem to your Internet provider who may or may not be able to/willing to correct it or you can go to Control Panel-> Administrative Tools -> Servidces and turn off the Messenger Service. Doesn't really effect much on a home system because no one is going to call your computer anyway.
Personally I don't remember having this problem before I got a computer
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com
What is this pop up on Vhelp ?
By Noahtuck in forum FeedbackReplies: 3Last Post: 18th Aug 2010, 16:08 -
Spyware / Adware / Pop-up HELP!!!!
By DVWannaB in forum ComputerReplies: 5Last Post: 13th Oct 2008, 20:16 -
Pop up doesn't go away
By jyeh74 in forum ComputerReplies: 20Last Post: 22nd Sep 2008, 05:54 -
Pop-up video
By uniks in forum Newbie / General discussionsReplies: 19Last Post: 29th Aug 2008, 22:44 -
A pop up
By imkool in forum Software PlayingReplies: 1Last Post: 19th Feb 2008, 13:11
