  1. Hello guys,
    I want to open an avi-file in TMPGCEnc but I recieve the message: "Canīt open or unsupported!"
    What is the problem?
    Thank u and
    bye damm2000
  2. Is it a divx avi? Sounds like you need a divx codec on your system. Hard to tell though, you don't give alot of info on the file.
  3. Dowload latest codecs:
    www.divx.com
    It could also be an audio problem(ie:maybe you'll have to convert to Wav and muliplex)as below:
    www.vcdhelp.com/virtualdubaudio.htm
    Feb 2001
    Berlin, Germany
    Assuming you have installed the codecs properly, go to option > enviromental settings > VFAPi plugin. Right click on directshow multimedia file reader and higher its priority.
