Greetings to the forum, I bought myself recently a Combo dvd-v5600 Samsung that reads DivX , I need to know if somebody knows where can find an upgrade of the firmware to be able to reproduce DivX 6, because nothing else reproduces until the version 5. in the official place of Samsung they don't offer this service... in case it exists, I need to know as making it![]()
Any big serious help.
PD: I don't speak English, grammar's problem or expression, please excuse me.![]()
Divx 5 & 6 are very similar. If you have Divx 6 files that don't play on your player, you will most likely need to re-encode them to make them compatible. You can check the files (the ones that work and the ones that don't) using a program like gspot. You should then be able to see what the differences are between the files. Chances are, the files were encoded using an option that you player doesn't support...a firmware update won't fix it.
Google is your Friend
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 15:25 -
ANyone have the older Samsung DVD-HD941 firmware upgrade?
By markharris in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Nov 2010, 17:49 -
Firmware upgrade crashed Samsung DVD-VR320
By spoonleg in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Apr 2009, 15:55 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 07:50 -
Samsung v5600 region free but picture is messed up
By daniel86 in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2007, 10:53
