Hi, just purchased Toast Titanium 5. I want to do the following:
1)create a slide show of still pictures with an audio soundtrack and make it a VCD.
2)I have 10 quicktime movies (about 5 MB each). I want to make them all play consecutively when put in a DVD player.
Does anyone know how I can accomplish these 2 tasks or some links where I can read about it?
Jason
I an new to this myself but what I would do is the following:
1) Export all 10 clips using QT in DV format
2) Load them into iMovie
3) Manipulate with transitions etc ...
4) Burn in Toast VCD format
5) Done
Regarding the slide show. Do the same as above but in step 1 import the stills, add timing to how long you want them to show in one place (A function of iMovie) then burn in Toast VCD format.
iMovie has a toast extension so you should have no problems.
-S -
Yes, iMovie will be able to import the .DV streams that you create. Just make sure that you set the quality of export to a level that you can watch without getting a headache.
-S
First Time Ripping...Looking for advice...
By zagro002 in forum DVD RippingReplies: 10Last Post: 19th Apr 2012, 00:07 -
Advice needed for 1st time HTPC
By hanugro in forum Media Center PC / MediaCentersReplies: 19Last Post: 17th Mar 2012, 13:07 -
How to you time subs on the fly with Subtitle Creator?
By Nagashi in forum SubtitleReplies: 1Last Post: 15th Apr 2010, 08:05 -
Making DVD video taking very long time. For advice.
By seymoria in forum Authoring (DVD)Replies: 4Last Post: 11th Mar 2008, 03:59 -
FAVC 1.04..Please Advice..Every time I convert PAL to NTSC
By sandman423 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2008, 22:21
