Hi All
I am thinking about investing in a stand alone DVD recorder for my living room. I have been doing some reading but I don't seem to find a definative answer to the following question. Are you able to connect the RCA Out from the TiVo box to the input of a DVD Recorder and burn directly from TiVo to DVD. I know it is able to connect to a VCR so i was hoping that it would do the same with a DVD Recorder and maybe record in real-time direct on to a DVD.
Thanks in advance
Coops
I do this all the time: spooling stuff off of my Tivo Series I and onto DVDs.
Theoretically, the results will not be as good as if you were to take the digital stream out of the Tivo instead of going from Digital->Analog->Digital, but I haven't seen any artifacts that were annoying to my eye.
Mark Z. -
Ditto. It's also much easier than moving the files to the computer, encoding, authoring, and burning a disc.
Google is your Friend -
Many thanks all. I am off to see what I can find while here in Toronto and make use of the strong exchange rate
Coops
Tivo to DVD Burning Issue
By jdogg2603 in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2010, 07:27 -
What are the advantages of a dvd recorder over tivo?
By zanos in forum DVD & Blu-ray RecordersReplies: 28Last Post: 29th Nov 2008, 13:44 -
Tivo (SVCD) to DVD - Brain Fart?
By fredfillis in forum Authoring (DVD)Replies: 0Last Post: 14th Sep 2008, 18:48 -
Need advice for buying a desktop DVD recorder.
By Xandaum in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Jul 2007, 11:16 -
Can Anyone Recomend a DVD Recorder DeskTop with a Hard drive?
By scustalow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th May 2007, 08:08
