I'm tryin' to rip an audio stream from a video and i'm havin' a problem:
i use VDubMod to do so.
i choose File>Open Video File - Opening my video and then:
Streams>Stream List - in the "Available Streams" window i choose "Save Wav", i'm saving - and for some reason - nothing happen! it doesnt save it! its ignoring my request!
am i doing it right?
is there any other way to rip audio?
THANX!!!
I don't know why that wouldn't work if the audio file is there, but I would select 'Full processing mode', or you may end up with a WAV container with the original audio format instead of just a WAV. You may want to check that the 'Compression' is set to 'No compression (PCM)', but that's the default anyway.
A few other demuxing tools: https://www.videohelp.com/tools?s=111#111
Is there a way to change JUST the audio on a video clip?
By jbitakis in forum AudioReplies: 6Last Post: 12th Dec 2011, 16:00 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
audio rippin question
By completetech in forum AudioReplies: 2Last Post: 5th Apr 2009, 09:04 -
AVI Video Clip Without Audio
By jdvideo in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2008, 15:03 -
How do I dub over the audio on a video clip?
By SpeedKills07 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2007, 06:19
