I mean how do you keep the audio as ac3 without re-encoding?
I use VirtualDub Mod for that. Open the Xvid video. Use the 'Add' in the 'Streams>Stream list' to add your AC3. If you already have a audio file there, move your new audio to the top, then select your old audio and click 'Delete'. Then save both the audio and video as a 'Direct stream copy'. This only takes a few minutes.
BTW, if your original audio file is MP3, you won't gain anything from this, except a larger file. If you are converting a MPEG to a Xvid, first you will need to demux or save out the audio, then add it back later. VDM can do that also.
Or you can just convert the MPEG to Xvid with VDM and it will keep the original AC3, if that's what it contains. You may need the AC3 ACM Decompressor to open the file.
ffmpeg encoding to xvid + ac3 5.1 -- can't make it work!
By suroit in forum Video ConversionReplies: 2Last Post: 4th Jan 2012, 16:13 -
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 05:59 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35
