i have some made for internet movies, released in segments/acts and available either wmv or QT formats
I DL the wmv formats, they are 720*480
convertX works to convert them, but i was wondering IF there is another program that will give even better quality video results
I've had good luck using the newly released TDA3 (TMPGEnc DVD Author 3) program. It will convert to either divx or Standard DVD.
Open it up, choose DVD or Divx, start a new project, add your clips, set any chapters, create a menu and let it convert to divx or convert to DVD and author as a DVD. Use the built in burning tool and burn.
As I say I have fed it WMVs, MOVs, FLVs, DVDs, Mpegs, Ogg and MKV.
As long as the proper codecs are installed and the files are not corrupt it works.
Good Luck
Whether or not the quality would be better, you'll have to decide. Download the trial version and test.
WMV to MPEG2 converter
By siluet in forum Video ConversionReplies: 1Last Post: 5th Oct 2008, 13:13 -
How do I include wmv to a dvd with mpeg2?
By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 21:50 -
Anyone knows how to convert ASF / WMV to Mpeg2
By macuser1960 in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2008, 17:38 -
Best App for Converting MPEG2 files to WMV/WMA 5.1
By JBredensteiner in forum Video ConversionReplies: 13Last Post: 7th Oct 2007, 15:58 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 13:27
