Ok can some tell me how Nero Vision is working better than Encore dvd 2? A friend copied all of the current episodes of Heroes and put them on a disk for me. The files are mpg4(xvid). I checked all the files and they are fine. When i use either premier pro to convert them the audio becomes out of sync. If i use encore dvd some along the line the audio drops out. The original files are all fine and in sync. I switched to nero vision and everything is fine. What could i have done wrong? My pc isnt old i have the following for those wondering about specs
Intel core 2 Duo 2.4 E6600
Ram is 2 gigs total
3 hard drives main is raptor 150gig other 2 are 250 gig and 320 gig
Anyone else have this problem
Adobe Encore DVD 2 not build to work with mpg4(xvid) files.
Use ConvertXToDVD instead. -
I converted the files first then i checked to make sure the conversion isnt out of sync. When i use Encore either the sound drops out towards the end or it gets out of sync. i wound up just using Nero for the episodes
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Burning DVD Encore 2.0
By Usagi Tsukino in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2009, 14:10 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
DVD duration on Encore
By bltprf in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 10:23
