Hi,
I'm just entering into the DVD recorder market, and I bought an inexpensive Lite-On DD-A100GX model. My problem is with chapter markings.
1. The first time, the unit was set to automatically insert chapter marks every 5 minutes. After finalizing the disc, I inserted the DVD into a couple of other players, and it recognized the chapters just fine.
2. Then on another recording, I turned off the auto chapter function and manually inserted chapter markings while it was recording, folllowing the instructions. After finalizing the disc, I played the DVD in the same Lite-On unit and the chapters worked fine. But when I played it on the other DVD players, it did not recognize the chapters at all.
(for both recordings, I used a DVD-R)
I don't understand why other players recognize the auto chapter markings, but not the manual markings.
I really need to be able to manually insert chapter marks, but still be able to use those chapter marks on other players, not just the Lite-On.
Is there a way to do this?
If not, is there another recorder that I should consider? I still have time to return this recorder if it's just too cheap of a model.
Thanks!
Lisa
	The chapter marks are the only problem you have sharing your Lite-On disks???????
 The rinky-dink menu structure with truncated fields doesn't embarrass you.
 I reauthor on my PC, the DVDs I record on my Lite-On if they are going to be used by anyone but me. Improving the menus and creating the chapters I want.
	No, I'm not sharing them with anyone. (and yes, it would be an embarrassment to share them "as is"). I do some video editing of home movies, but I hook up the video camera straight to the computer via Firewire, do all of my editing on the computer, and then finalize and burn DVD's from the computer. I don't really need this Lite-On unit for that function.
 I'm trying to clear off space on my Tivo, so I'm recording onto the DVD's the things we want to keep or don't have time to watch right now. Therefore, these recordings are for "in-house" use and I'm not too concerned about the aesthetics. I'm mainly trying to find a fast way to get rid of stuff from my Tivo and let the kids/husband/family watch it later, which may be on a different player.
 Is that the only solution...to reauthor them? Like I said, I'm looking for a fast method, and don't need anything fancy for a bunch of TV shows.
 Do I need another model?
 Thanks,
 Lisa
	Lisa - I'm sorry but I can't help you with your problem. I can tell you that you better get used to weird things like this happening with discs you make with DVD recorders. I bought my dad and step-mother a DVD recorder to replace their old VCR. It was the same model as yours and my dad had no problems using it once I hooked it up. However, the DVDs it produced would not fast forward at all on his old Pioneer DVD player. It became a big issue for my step-mother because she is one of those people who have an irrational hatred for commercials and she just completely loses it if she has to watch a commercial. I am not exaggerating. Anyway, my dad bought a different brand of DVD recorder and replaced the old Pioneer player with it and the LiteOn made DVDs would now "magically" fast forward with no problems. One of my friends told me that he's seen similar problems with older DVD players, so he only plays back discs on DVD recorders. Sorry, but I can't say I'm surprised that your LiteOn DVDs have chapter access problems when you set the chapters manually. I don't know why that problem exists though, but probably manual chapter points don't get set the same way as when it's programmed to do it every so many minutes and whatever way they are being set manually probably isn't quite by the book, so other players don't understand it.
	learnin to burn
 I do not have the Liteon A100GX But Do have six Liteon/ilo recorders.
 both with and without HDD
 I'm not going to enter in a recorder opinion review But my units With HDD are somwhat more easy to edit than those without The Liteon is a very good machine. and in the Real world the result is as good as any.
 I do not Use the chapter markes as you indicate and i have not had any problems
 I would suggest that you consider a Reusable +RW disk
 LiteOn made the Ilo-04 series and makes many drives and units for a large number of venders.
 including Sony
 I would suggest that you post your concerns at these sites [Rember Ilo is Liteon]
 http://www.techolio.com/forums/phpBB2/viewforum.php?f=7&sid=f6a7253cede5865aa7111e454ace6800
 http://www.normediasolutions.com/forum/viewforum.php?f=12
 Edit
 I have not had the issues you mention with my 2 Lieton 5005 an ilo-R04But as said I have not used them for this but do the 2 RHD-04and 5045 with HDD
 When I did, had no proplem inserting chap marks and playing them on other machines It could be a operation missunderstanding but as said I do not have that unit.
	[quote="Learnin to Burn"]Hi,
 HOW DO YOU FINALIZE WITH THIS PLAYER? I CAN'T FIGURE IT OUT, AND OF COURSE IT's NOT IN THE BOOK! PLEASE HELP THANKS!
  Could we use the DVDremake tool to remove DVD Chapter Marks?By jjulio1 in forum DVD RippingReplies: 1Last Post: 5th Aug 2010, 10:41
  Editing the chapter marks in a dvd ifo fileBy jjulio1 in forum DVD RippingReplies: 1Last Post: 5th Aug 2010, 06:03
  Problem with transitions/chapter marks using Nero 7By dvdtcb in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2009, 12:58
  Re: getting interactive chapter marks windvd creator 2By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38
  I would like to insert chapter marks and possibly a menuBy the six-teens in forum Authoring (DVD)Replies: 3Last Post: 9th Jul 2007, 21:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
