Hi,
I keep reading on this forum of the best way to keep video quality high is to demux the audio, re-encode it in AC-3 to allow a higher bitrate to be used for the video.
However,
If my DVD's are only ever a maximum of 60mins, do i still need to go through the above process? Will i achieve any visible quality difference, or can i leave the audio muxed in with the video and encode at a high enough rate that i won't see any difference?
I'm prepared to go through the process if necessary, but i don't want to go through the effort if i won't actually achieve any gain?
thanks.
-Stu
Where does your original video and audio come from?
Encoding audio to AC3 is pretty fast.
On my PC, about 1 minute/20 minutes of sound.
Video however takes at least 2 minutes/minute of video; i.e encoding audio is about 40 times as fast as video (roughly). So saving time encoding audio is minuscule compared to the total.
However, one hour of WAVE (uncompressed) audio is about 500 MB.
High-quality AC3 is about 100 MB. The saving is pretty large and if used for video should make a noticeable difference.
But anyway, easy enough to make a few test files and see for yourself if it matters. -
Originally Posted by AlanHK
1) So how do i go about seperating the audio/video signals
2) How do i convert from .wav to .ac3
3) How do i get the audio back to the video and perfectly synchronised?
Can i do as current, ie do all my editing etc of both video and audio in adobe prem, then when i'm completely finished, instead of rendering to mpeg2, is that where i seperate the audio?
If done at this stage, would that mean that when i put the two files back together i don't need to worry about synching, because it should already be synched? Or because of the compression, does it need to be re-aligned with the video?
I guess that's the main part that scares me, is just how difficult it sounds to get the audio perfectly in sync with the video??????
I don't use Premiere. but I'd be amazed if it couldn't handle all the common audio formats by itself.
I suggest you ask a new question, with Premeire in the title and you'll get some more applicable hints.
Extract audio from MP4
By aiyoyo in forum Video ConversionReplies: 5Last Post: 12th Dec 2013, 15:35 -
how to extract audio from avi
By ShrinkDWorld in forum AudioReplies: 2Last Post: 2nd Feb 2012, 17:58 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to extract audio from a MKV?
By takearushfan in forum AudioReplies: 3Last Post: 23rd Jul 2010, 23:51 -
Extract Audio from MPG
By vin4evr in forum AudioReplies: 3Last Post: 24th Dec 2007, 13:09
