Hi I'm just new too this forum and I have a big problem by my opinion.
I have a Strong LCD monitor.
The moment you turn on the monitor you have to press te power button and the inactive red light will go green for a couple of seconds.
After this it jumps back to red.
It doesn't matter if I connect a device through one of the inputs (DVI-I, Component,S-video or the regular 3 cable connection don't know the name from my head.)
Does anyone have any clue?
Thank you in advance,
Ilker van den Berg
Sounds like you aren't selecting the right input to your TV.
On your remote, there should be a button labeled "Input" or "Video".
I don't know if your particular TV has an on-screen display that tells you which input is active; some do.
Some TVs will also let you map a given input to a video, like:
Component->Video3 or Svideo->Video2.
Also, the particular input might have the video designation printed right by it, like:
Video 3
(Component)
Video 2
(Svideo)
Hope this makes sense. -
many monitors, go black if there is no input signal, your input signal needs to on before you turn on the monitor
if the signal is on and the monitor is shutting down, you have a broken/defective monitor,
time to take it to the shop -
it doesnt matter what i connect if i put it on first or after i start the lcd up.
Nothing happens even when i try to select the input
It doesnt show in the OSD.
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 13th Feb 2009, 00:01 -
LCD Monitor Problem
By Soopafresh in forum ComputerReplies: 8Last Post: 27th Apr 2008, 04:11 -
Weird Toshiba HD-A2 problem on a standard PC LCD monitor
By danimal99 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Nov 2007, 13:07 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29 -
LCD Monitor...is it a problem?
By ron spencer in forum ComputerReplies: 6Last Post: 24th Sep 2007, 08:24
