Hi,
Are there any good DV samples available for download. I don't shoot, but I'd like to try encoding DV.
I'd like one of each 4: pal/ntsc prog/interlaced.
ty
Results 1 to 14 of 14
You can easily create your own DV to play with. All you need it Virtualdubmpeg2 and the Panasonic DV codec. Load up a VOB form a DVD, and save it using Full Processing Mode and the Panasonic DV codec. Et Viola - instant DV (well, almost instant).
There is also a DV sample file toward the bottom of this page : http://libdv.sourceforge.net/Read my blog here.
10 second clip, 16:9 NTSC interlaced, 36MB: http://www.nepadigital.com/reencode/avidv.avi
No audio but the video stream is the original from the cam. Pretty good clip for testing purposes cause it has flashing strobe like lights.
You probably won't find much because of the huge file sizes. -
With DVdate you may create samples in DV Pal or Ntsc but always interlaced. I do not know any sample in DV not interlaced. Does it exist?
To do so open any video AVI in DVdate and apply the command "Convert to DV type2" in the menu Convert. The sample will be 4x3 or 16x9 according to the nearest image ratio of the original AVI.
You may also choose the audio :32000 Hz or 48000 Hz, and even the seldom, but legal frequency in the DV standard of 44100 Hz.
You may after that convert the sample to DV Type1.
So you may have samples combinig Pal/Ntsc, 4x3/16x9, 32000/44100/48000, Type1/Type2 that is to say 24 different types of samples.
All this can be done without any specific codec, if Directx is installed on your computer.Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
Thanks for the info and links.
I have no interest in the files having audio.
I have a preference for dv shot in dv. If needed though I'll use all your suggestions for creating a dv video out of a dvd. -
did you install a DV codec ? - and never use QT for playback anyway
I've got ffdshow.
Tried panasonic dv codec.
I can play the other available .dv files with quicktime.
If not quicktime then what? -
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Thank you for confirmation.
The club scene is pretty poor. Strobe lights is all it provides.
If anybody can think of any other available samples, it would be nice.
I might end up trying the 'create your own dv" methods suggested.
I also should track down a friend who shoots weddings for some footage.
ty -
Actually, its a good test clip for MPEG encoders. MPEG has a difficult time with strobing lights.Originally Posted by 45tripp
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
Motion² - first samples!
By nitro1973 in forum Software PlayingReplies: 1Last Post: 25th Apr 2010, 16:00 -
Video Codec Samples?
By prdffy in forum Video ConversionReplies: 8Last Post: 8th Mar 2010, 03:52 -
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 06:41 -
DVD samples
By michcio in forum Video ConversionReplies: 14Last Post: 10th Jul 2008, 19:53
