    Mar 2007
    Trinidad and Tobago
    After I finish a title on a dvd, I would like the dvd to return to the main menu after playing the selected title and not go on to the next title on the dvd. Without having to reincode, can I just edit the IFO with IFOedit or some other software? And if so, how?
    Aug 2004
    Are you familiar with pgcedit?
    Try this:
    1) Open dvd in pgcedit
    2) Click on the title you want to go to the menu and look at the post commands.
    3) Change the line where it jumps to the next title by double clicking on it. Click on alphabetically --> CallSS-VTSM. Untick (if any) checkmark next to if GPRM. Your changed line in post commands should read something like - (CallSS) Call the VTSM Root Menu of the current VTS. If your main menu is in vmg menu, then you would CallSS-VMGM-Menu instead.
    4) You can test using trace mode in pgcedit. Or test in a software dvd player AFTER saving DVD (next step).
    5) Save DVD
    Mar 2007
    Trinidad and Tobago
    Thanx! Worked like a charm
    Come Visit the G Spot!
