    Oct 2003
    Canada
    I'd like to play around with Adobe Audition, and make a music program for the internet. Can I get some suggestions as to which sort of mic and/or hardware I would need to give reasonable quality.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    what are you gong to record and how far away ?
    Oct 2003
    Canada
    Just voice
  4. Member Soopafresh's Avatar
    Jan 2004
    USB mics are really convenient for PCs. The Blue Mic Snowball is a good one -
    http://www.bluemic.com/products/accessories/pics/snowball_takealook_wtripod.gif
    $150USD and is sold in Canada at Long & McQuade
    http://www.bluemic.com/modules.php?op=modload&name=Products&file=index&prod_id=18
    You'll also want to add dynamic range compression to the final mix to give it that "radio" sound. You can do that either in Audition, or use the free Levelator app to accomplish this. (Google it)
  5. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    I bought a Blue Snowball on eBay and I can't say enough good things about it. It was about $100 (USD) plus shipping.
    BTW, blue makes excellent professional microphones. The Snowball is their first prosumer product.
