    Mar 2007
    My friend has some movies that have been burned on CDRs. I would like to make copies but I want them on a DVD. Can I burn them to a DVD and if so how? If they can't be on DVD how do i copy them to a CDR? I have no idea what programs were used to burn these movies to CDRs. I use DVDFab to burn movies. These may be stupid questions but i'm just learning.
    Just copy the files from the cd and burn on a dvd.
    Or do you want them as a dvd-video that should work on most standalone DVD Players? then use ConvertXtoDVD or DVD Flick and add the movies and convert to DVD-viDEo.
    And this is not any DVD to conversion. Moving you.
    Mar 2007
    I do want to be able to play them on my DVD player not just the computer. I will try your advice and thank you so much for your help.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If they're VCDs, use SVCD2DVDMPG.
    Mar 2007
    They are svcd. Thanks for you help
