Hi all,
havent been here for quite some time. I have a delima.
I recorder several shows into a DVD-RAM using my Panasonic DMR-ES25 DVD recorder.
I can take this dvd, put it into my DVD-RW on my PC and am able to view the show (shows up as 1 show).
I would like to transfer this DVD to AVI/MPG so I can edit it and remove the commercials, then make chapters for every show (6 in total) then re-burn it to DVD.
What software to I need to do all this (prefeerable free, but if I have to buy 1 software that will do all this, then im willing to do that).
Is there a guide for this?
Thanks for the help.
tmpgenc dvd author, it can import the dvdram and edit,add chapters and burn to new dvd. not free though.
I use Tmpgenc MPEG editor to import the shows from disc to my hard drive, edit them, then export to an mpeg2 ready for authoring, this is pretty quick with no re-encoding required.
isnt there free tools to do this?
I downloaded tmpgenc dvd author, everything seems good but when editing the different shows, it does not allow me to cut (delete) the scenes (commercial)... -
im trying a demo of Womble MPEG Video Wizard and it seems alot easier to work with at first glance. I'll report back.
DVD-RAM to AVI.
By aliciac in forum Video ConversionReplies: 16Last Post: 1st Apr 2011, 15:29 -
DVD to AVI Or MPG
By AeR0 in forum DVD RippingReplies: 10Last Post: 4th Mar 2010, 19:59 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Help about Enconding AVI to DVD MPG!
By ardiani in forum Authoring (DVD)Replies: 5Last Post: 30th Sep 2007, 12:33 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 23:13
