    Jan 2003
    Nassau, Bahamas
    I just recently purchased an epson rx580, and im looking to run it wirelessly from my linksys router, except, all the wireless print servers i find, require me to run a cord to the printer. Can anyone recomend a print server, with two different pieces of hardware so i dont have to run a cord between the router and the printer...thanks
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. you don't need a cord between the router and the printer, you need it between the print server and the printer. This is unavoidable unless you get a network printer (yours isn't).
    Depending on your setup (wireless) you may need to temporarily connect the print server directly to your router via an ethernet cable - but only to configure it.
    After that, your print server (I use a very small belkin model) can sit next toor behind your printer, connected via a short usb cable, with no other connections back to the router other than the invisible wireless one.
    Since your's is an "all-in-one printer", a device like this should fit the bill:
    http://www.amazon.co.uk/Wireless-G-All-In-One-Print-Server/dp/B000KTQ456
    Jan 2003
    Nassau, Bahamas
    ok..this is what i now noticed, first off i need a wireless router which i dont have. Something that looks like http://www.newegg.com/Product/Product.asp?Item=N82E16833124052
    Then once that is configured, to my computers, then i place one of thses devices and configure it next to the printer
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT&viewi...7025&rd=1&rd=1
    http://www.newegg.com/Product/Product.asp?Item=N82E16833124042
    and then i should be able to let my printer stand alone, by the looks of the first wireless print server. If i am completely wrong, please recomend both router and print server for my self, or, my network storage and print server in one...holla back
  4. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    You can go with a Bluetooth Wireless Printing kit which includes a Bluetooth adaptor for the PC and a Bluetooth Wireless Print Server. You can also buy the adaptor and the print server separately. This should be cheaper than buying a router and a wireless print server, but if you have a need for a wireless router anyway, that might be a better route. Check Google or PriceGrabber.
    Nothing can stop me now, 'cause I don't care anymore.
