how to convert vlc file to avi/ mpeg/ other's common format???i'm downloading video's from youtube... hehe.... thx...
I'm not sure what you mean by a 'VLC' file.
Try dropping the file into Gspot 2.60 and that will usually tell you the format it is. But VLC can also transcode a file to a more 'normal' format. But the better method is usually to identify the original format, then pick an encoder that can convert it to a format that you want.
YouTube may be FLV format. You might look into the freeware SUPER if you can't get the VLC transcode option to work. Or take a look in our portable video tools: https://www.videohelp.com/tools?s=36#36 You may find programs there more suited to those type of conversions. You may also need a program to download the video:
https://www.videohelp.com/tools?s=39#39
And welcome to our forums.
How use VLC to convert Youtube flv files to other video formats?
By solarblast in forum EditingReplies: 1Last Post: 24th Jul 2011, 14:43 -
Convert .Tivo to .MKV (not using VLC)
By DarkPhoenix77 in forum MacReplies: 3Last Post: 18th Jun 2011, 10:29 -
Help with VLC player convert feature!!
By dannyzero in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2010, 13:57 -
VLC media player file?
By HartsVideo in forum Software PlayingReplies: 11Last Post: 19th Feb 2008, 14:42 -
VLC , WME convert
By arwa in forum Video ConversionReplies: 5Last Post: 30th Oct 2007, 12:58
