Hi
I've always used SUPER to convert FLV files to DivX or XviD but now I want to convert an FLV file to a normal AVI file so that I cant play it in my VCD/DVD player. How can I do it?
There is no patch for ignorance...
Other way...
http://www.digital-digest.com/articles/FLV_to_AVI_Conversion_Guide_page1.html
FLV Extract > VirtualDub + ffdshow VfW + DivX or Xvid -
to play on a DVD player , the player has to be Dvix compatible, its more common than it used to be, but my player i bought 2yrs ago does not play dvix files
if your player is Dvix compatible, it is probably easiest just to download Dvix 6 creator from the official website and use that to convert your files, then you burn a data disc or menu disc with the files
I have never done this, other here can recommend the programs to use and the formats you need -
Supposedly, the newest version of SUPER has no problems handling all forms of FLV, too, and converting to AVI. I wouldn't recommend installing the current version, though, as it reportedly has a number of problems that are (also reportedly) fixed in a new build to be released sometime soon.
Animated .GIF super-compression
By JJones in forum Newbie / General discussionsReplies: 5Last Post: 13th Aug 2011, 16:08 -
YouTube FLV to MP4 with SUPER?
By terrypin in forum Video ConversionReplies: 0Last Post: 28th Dec 2010, 06:06 -
Looking for a super fast converter that will handle flv-to-avi
By snafubaby in forum Video ConversionReplies: 2Last Post: 14th Nov 2010, 07:42 -
Using SUPER to convert AVI to FLV; afterwards...how to upload?
By jmcconnell86 in forum Video ConversionReplies: 1Last Post: 13th Jul 2009, 19:48 -
Need confirmation of this SUPER settings to copy stream from FLV to AVI
By ohboy888 in forum Video ConversionReplies: 2Last Post: 20th Feb 2009, 04:59
