I have a DVD, PAL. I used dvd decrypter to put the VOB files to my HDD.
Then I used VOB2MPG to make them into 1 4GB MPG file.
When I load it to TMPG DVD Author, it says it's PAL. Of course. I need NTSC though.
So I read up that TMPGEnc can convert... so I tried*, but the resulting are:
VTS_01.m1v -- plays fine with VLC, no audio (of course)
VTS_01.mp2 -- doesn't hear anything using VLC or Windows Media Player
And the combined two only makes 1.46GB. Something's weird. From 4GB to 1.46GB.
I did something wrong with TMPGEnc. I use TMPGEnc Plus 2.5, btw.
When I muxed them back using TMPGEnc Plus 2.5's MPEG Tools, I get error after finished:
"20xxx something caused buffer underflow. This may cause some problems bla bla"
Don't quite remember what... but the resulting VTS_01.mpg does not have any audio.
Note:
*This is what I did. I ran the program.
Video source ... [browse]. I clicked [browse], I chose the MPG file.
Nothing for audio, I think.
I pressed [Settings]
:VIDEO tab
changed size to 720x480
changed aspect ratio from 4:3 625 line (PAL) to 4:3 525 line (NTSC)
changed frame rate from 25fps to 29.97fps
rate control mode: CBR (untouched)
rest: untouched
Clicked [ok]
Back to main, clicked [Start]
Waited 3 hours (sigh)... finally finished. Results are above.
Any help?
Thanks.
AFETR YOU HAVE RIPPED THE DVD TO YOUR HARD DRIVE AND THEN USED DVD SRHINK, OPEN NERO ULTRA 6 OR NERO ULTRA 7 AND USE NEROVISION EXPRESS TO CONVERT PAL TO NTSC FORMAT. THIS WORKS VERY WELL FOR ME.
Lawrence Johnson -
lbjohnson - please don't use all capitals. It is considered shouting and rather rude. And FWIW, NeroVision as a solution in this instance is not something worth shouting about.
Read my blog here.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
Proper PAL-to-NTSC conversion, and viceversa
By jeanpave in forum Video ConversionReplies: 15Last Post: 14th Jul 2009, 21:20 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
