    Mar 2007
    I'm trying to convert a xvid avi file that has a ac3 sound file. I'm reading the guide on how to convert it to vcd so I can play it on my dvd player. And It's been said that mp2 audio works on almost all dvd players. What I wanted to ask is can tell me step-by-step how to convert wav to, mp2 with the two programs metioned in more detail than given since I have gotten to the point of converting the ap3 to wav.
    Thank You.
    Ps this is the guide I'm using.
    https://forum.videohelp.com/viewtopic.php?t=140703
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    For VCD you do not have a choice but to use MP2 audio.
    AC3 to wav guide: https://www.videohelp.com/virtualdubaudio.htm
  3. You can use the BeSweet GUI Preset for SVCD MP2 audio. Real easy.
    Mar 2007
    How do I do it ? When I click "wav to mp2" it says "can't find file".
    Please help.
    Thanx.
  5. Member Soopafresh's Avatar
    Jan 2004
    Use the Belight GUI instead - it is newer and more intuitive.
    http://coreforge.org/frs/?group_id=27&release_id=7
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    In that mode it's looking for the last wave file you converted, which probably has been deleted since. Up on the top left of the main screen, under "Locations", use the "Input" selector to find your file.
    I generally use the "Wizard" mode, simpler than the full-on one, it has all the options I need. But for some odd reason, when you do "Select source" it doesn't show you .wav files as a "Supported file". But if you right-click on the little arrow to the right of the "file type" box, and change to "All files", you can see and select wave files.
    Dec 2002
    Costa Rica
    To convert from WAV to MP2 you could use tooLame and the tooLAME Gui
    This little program is simple, yet very powerful.
  8. Member Soopafresh's Avatar
    Jan 2004
    And there's always ffmpeggui
