Closed Thread
    Mar 2007
    Singapore
    hi, recently i got myself a PVP which only accepts asf files encoded using the provided Sunplus Transcoding Tool. My main probs with the software is tat it cannot convert rmvb files directly n doesnt batch-encode. I can find a workaround for the first problem, but not being able to batch-encode files means i have to slowly convert file by file, which is madness. So i was hoping to find another tat does.
    Anyway, I ran a file encoded with the Sunplus proggy through MediaInfo, and tis was wat i came up with:
    General #0
    Complete name : G:\HC03.asf
    Format : Windows Media
    File size : 147 MiB
    PlayTime : 22mn 39s
    Bit rate : 908 Kbps
    Video #0
    Codec : DivX 4
    Codec/Family : MPEG-4
    Codec/Info : Project Mayo DivX 4
    Bit rate : 511 Kbps
    Width : 352 pixels
    Height : 240 pixels
    Aspect ratio : 1.467
    Audio #0
    Codec : ADPCM
    Codec/Family : ADPCM
    Codec/Info : Intel ADPCM
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48 KHz
    I also tried Mediacoder to replicate this format, but i realised their options of 'MPEG4/MS-MPEG4-V2' is different from the DIVX4 codec found in Sunplus, and i'm guessing tis is the reason why my attempts failed.
    So it seems to me, tat I nid to have a file tat's encoded using DIVX4 video (and not the newer divx versions), adpcm audio, in an ASF container. Any idea how I can do tat?
    one post is enough.
