    Mar 2007
    hi every body
    i have a video which is .avi fomat v it has a audio in AC3 format
    i am trying to convert the ATSC/A-52 Dolby AC3 audio to AUDIO layer 3 MP3
    is there any way to convert it.
    as far as i know i have to extract the audio and convert it and then append the audio can do it
    but i am not being able to find the software to do it. some body should help me here.
    if there any way to convert the audio with out extracting it will be even better
    thanks in advance.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Ignore, doesn't work correctly.
    He's a liar and a murderer, and I say that with all due respect.
    Mar 2007
    what do you mean does not work
    i can not do it
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    First: Why?
    If you really have to, first make sure you have AC3 decoding and MP3 encoding set up (AC3 ACM codec + Lame MP3 ACM)
    Load AVI in VirtualDub, set video to direct stream, audio to full processing, select and configure Lame MP3 to suit you, and save as new AVI.
    /Mats
    Mar 2007
    Originally Posted by mats.hogberg
    First: Why?
    /Mats
    thanks for your suggestion i will try it
    i want to convert because the rmvb converters are not supporting the AC3 audio format...
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    In that case, convert the AC3 to wave. Converting to MP3 will lose quality unnecessarily. Wave files are much bigger than MP3 or AC3, but you only need it temporarily.
    Mar 2007
    virtual dub is doing it so easily thanks for your help mats.hogberg
    my problem has been solved.
    thanks to alanhk too
