ok, i've been searching forums for a good 8 hours now and i finally broke down and started to post. yes i've tried the search button and google. ok here's my problem.
i want to play larger video files.. 500mb+ - 1gb... the files, they play but, every 10-20 seconds i get a delay in the playback(just for a split sec or 2). the video and audio stay in synch. i've been able to play these larger movie files on this system befor. i've recently reformatted, and i did install my video drivers and updated them the same way as i did befor. smaller video files play allmost flawless. i've tried a lot of diff troubleshooting... closing EVERYTHING. i disabled all unnessasary system services. i've turned down hardware accelleration.. i've tried changing to lower colours. i have a radeon 7500 video card, which i uninstalled and reinstalled drivers.. and tried on older drivers also.. i really dont know what to do.. these movies, they used to play just fine. so if anyone has any other idea's please share!![]()
If your stats are correct, you have a pretty slow CPU with average memory. I would start by looking at what else is running in the background that might be hogging CPU or memory. You might also defrag your HDD if necessary, and try a different player. I would suggest VLC to begin with, as it rules out other codec issues at the same time.
Read my blog here.
You need to run a good spyware checker and anti-virus scanner. Your system is vulnerable to all kind of malicious software.
Update your XP to SP2 and get the latest Windows patches.
Defrag the HD on a regular basis. -
i tried vlc. and ya i have service pack 2. and like i said i reformatted like 2 nights ago so i dont know how defragged i am yet. i use tca and tcm and i just scanned with hijackthis and i dont see anything that looks suspicious. and i litertally shut off everything that could use sys recourses.. i disable almost everything in system services besides what i need for audio/visual. same delays in the playback
trog, I locked the two duplicate posts. Please don't crosspost. Please read our rules before posting.
Moderator redwudz -
Make sure the hdd ide controller has dma turned on. It's a likely culprit and the most frequent cause of playback problems.
If that's not it then next I would see which codec is being used to play your files ie if they are xvid/divx are you using the divx or xvid decoder or maybe ffdshow and try another.
You could also switch player some use internal codecs while others are more cpu/system intensive because they load and use on the fly video processing options to enhance the picture and or audio. Check the players under tools on this site for an alternative.
Hardware acceleration would help not hurt you as it takes load off the cpu but either way you should be ok.
btw) I didn't know about this thread I was going to answer elsewhere so what I posted may have already been said by others. -
good call on the player with built in codecs..GOM player very nice. playback very nice.. the occasional glitch maybe every 10-15 minutes but its much more tolerable.. ty again !!
Xbox 360 1080p MP4 Playback Issue - Video Flicker/Tear
By kfrye89 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jun 2011, 17:35 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
4:3 Playback issue with LG RC797T
By yumitree in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Nov 2008, 12:06 -
Playback Issue
By AllisonChains in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2007, 22:35 -
video playback issue.
By Twiz0r in forum Software PlayingReplies: 1Last Post: 28th May 2007, 10:05
