    We all use terms that we get used to using but don't have a precise definition in our minds of what the term specifically means. One of those terms is nonlinear editor. Does anyone have a clear definition of what a nonlinear editor is? Also, as compared to what other kind of editor?
  2. Originally Posted by http://en.wikipedia.org/wiki/Non-linear_editing_system
    A non-linear editing system (NLE) is a video editing (NLVE) or audio editing (NLAE) system that can perform random access on the source material.
    That's the key part.
    The first video I made was very much linear. No computer A source deck, a record deck, a CD player, a cassette player, an audio mixer, a ratty piece of paper with my audio cues, a fast hand and patience! It was like being a DJ!
    John Miller
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    NLE's typically have a time line so you can quickly jump to any point in the video without plowing through the whole file.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    By far the most important aspect:
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Linear Video Editing - http://en.wikipedia.org/wiki/Linear_video_editing
    Non-linear editing system - http://en.wikipedia.org/wiki/Non-linear_editing_system
    In simple terms, linear editing is a sequential process. Think of recording to an audio cassette. You start with song1, then "assemble edit" Song2, Song3, etc.
    If you later decide to replace Song1 with a different Song1b of a different length, then you are in trouble. A short song will leave a gap, a longer song will overlap Song2. So, you must start over and record Song1b, Song2 and Song3 from the beginning. This process is known as "assemble editing".
    Non-Linear editing allows you to rearrange and trim clips as much as you want because nothing is being permanently recorded. You are previewing from a virtual timeline that in reality is accessing the source files to simulate a linear playback. This can only be done if the source files are on random access media (e.g. hard drive). When you are finished editing, you "export" the virtual timeline to a linear file or other linear media like tape or DVDR.
