I would like to get analog video and audio into one of my computers so that I can capture from cameras, VCRs, etc.... and get to most easliy editable AVI (or MPEG2 which I can use VideoReoPlus to edit). I have wanted to get capture card that won't include having to add new potentially conflictinf video editing siftware to. (I have a Pinnacle device that only works with Pinnacle Studio installed....but as I use WMM or Premiere Elements to edit... adding such programs can be a road to conflicts such as codecs.)
Any advice or suggestions really appreciated.
Appears ATI Wonder may offer this with it’s TV tuner card. Are there TV tuner cards that wil also have RCA video - audio composite analog capture?
Thanks,
Brad
Brad
1. Dell Dimension 4550, Pent. 4 - 2.53 GHz, 1 GB RAM, XP Home SP2, 2. AMD 3000+, 512 RAM, XFX GeForce FX 5200 Video Card, Beyond TV 4.1 and Hauppauge PVR250BTV, Win XP Home, 3. HP dv8000, 1 GB Ram, -
I think pretty much any of the ATI All-In-Wonder cards will accept composite video; you may have to get an S-Video to RCA adaptor for somewhere in your stream if the connectors don't match, but that's it.
Along those lines, if you plan on editing your video at any advanced level (besides cutting out bad footage and/or moving scenes around without funky cool transitions), you'll most likely want to capture as AVI (DV or other compression) as that'll get you the cleanest quality for advanced editing. And I'm not aware of any hardware MPG2 device that also captures as AVI, though the ATI's use a combined hardware/software approach that gives you sorta the best of both worlds, plain AVI capture plus "on the fly" MPG2 recording (with software assist) for when you just want to do simple cuts.
Hope that helps more than it confuses! :P
EDIT: If you go the ATI route for AVI, or Hauppage for MPEG2, I can guarantee you'll find, in these forums, enormously helpful responses for pretty much any question you have regarding their use!
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
Imagine me, another problem w/ Vegas! Capture vid & render, no mp4 save?
By damonj_3 in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2011, 13:01 -
Seeking Software to Capture DOS Screen Motion and Audio
By Frank-0-Video in forum ComputerReplies: 3Last Post: 10th Jun 2011, 23:57 -
ATI 650 capture card: analog channels black&white
By lhughes in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2009, 07:34 -
cheap m.b, cpu, case package withonboard vid&aud&lan - @zipzoomfly
By minidv2dvd in forum ComputerReplies: 6Last Post: 25th Sep 2008, 04:07
