http://sox.sourceforge.net/
SoX, the swiss army knife of sound processing programs. SoX is a command line utility that can convert various formats of computer audio files in to other formats. It can also apply various effects to these sound files during the conversion. As an added bonus, SoX can play and record audio files on several unix-style platforms.
Sox is a general purpose sound converter/player/recorder that supports the following formats:
RAW sound data in various data styles
RAW textual sound data
Amiga 8svx files
Apple/SGI AIFF files
SUN .au files
PCM, U-law, A-law, G7xx ADPCM files
mutant DEC .au files
NeXT .snd files
AVR files
CD-R data (music CD format)
CVS and VMS files (continous variable slope)
GSM raw data (with optional library)
Macintosh HCOM files
Amiga MAUD files
MP3 files (with optional external library)
Psion Record.app files
IRCAM SoundFile files
NIST SPHERE files
Turtle beach SampleVision files
Soundtool (DOS) files
Yamaha TX-16W sampler files
Sound Blaster .VOC files
Ogg Vorbis files (with optional external library)
FLAC fiels (with optional external library)
Dialogic/OKI ADPCM .VOX files
Microsoft .WAV files
PCM, U-law, A-law, MS ADPCM, IMA ADPCM, GSM, RIFX (big endian)
Psion (palmtop) A-law .WVE files
Maxis XA Audio files
EA ADPCM (read support only)
Record and Play audio on various Unix platforms.
null file type that reads and writes from/to nothing.
The following effects can be applied to sound data:
Channel averaging, duplication, and removal
Band-pass filter
Band-reject filter
Base tone control
Compress and Expand (compand) the dynamic range of samples
Chorus effect
DCShift audio
Deemphases filter
Move soundstage to front of listener.
Add an echo or sequence of echos
Fade in or out
Apply a flanger effect
Apply a high-pass filter
Apply a low-pass filter
Apply an equalizer effect
Add dithering/masking noise to a signal
Multi-band Compander
Pad with silence
Pan sound between channels
Apply a phaser effect
Change the pitch of a sound file without affecting its speed.
Repeat audio data
Change sampling rates using several different algorithms.
Apply a reverb effect
Reverse sound samples (to search for Satanic messages![]()
Detect periods of silence and start and stop processing based on it
Change the speed of samples being played (without affecting pitch)
Display general stats on sound samples
Stretch/shorten the duration of a sound file.
Swap stereo channels
Create sounds with a simple synthesizer
Treble tone control
Trim audio data from beginning and end of file.
Apply a tremolo (a.k.a vibrato) effect
Adjust volume of samples.
Noise elimination using frequency profiling
Sox has been tested under Linux, Solaris, and Windows 9x and I have received success reports for various other platforms such as Irix and OS/2.
Version 13.0 available here:
http://sourceforge.net/project/showfiles.php?group_id=10706
Need libamrwb & libamrnb for SOX!!
By Shohag_ifas in forum AudioReplies: 0Last Post: 12th Jun 2011, 02:18 -
What programm, could take out pieces of video, and exchange them for other
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2008, 09:28 -
Which printer, exchange required for dud R230
By mikesbytes in forum ComputerReplies: 1Last Post: 5th Mar 2008, 06:51 -
key exchange for dvd copyright protection
By repeatrepeat in forum Newbie / General discussionsReplies: 6Last Post: 26th Aug 2007, 00:54 -
Exchange DVD Recorder for PC
By ispy in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 18:00
