hi guys im really struggling to get the end product i require. Ive tried encoing xvids / avi's to mpeg 2 but the out come seems to judder every 2 seconds when the video pans right to left and up and down. When its nearly still the video looks fine its just when fast action or camera panning it starts to judder almost as if its strobing... this is really doin my head in now and ive tried every way possible in tmpgenc 4 xpress to rectify it but no joy.. ive d/loaded a divx codecs but still no joy. Basically im trying to put 3 films onto 1 dvd 4.7gb i konw its possible as ive done it with reall great quality but they seem to be doin the above. ive gspot them to find the original framerate and set it to this in the source menu on tx4 (tmpgenxpress4) tried it in ntsc format / pal / progressive / unspecified etc.. im trying to get it into pal from ntsc, surely there must be a program out there that does this effectivly. Im also putting it through dvdlab so sound has to be at least 48kbs...
any help i would gratefully appreciate and not loose any more hair![]()
thxs
You're having problems because of the framerate conversion, you might want to try one of these: https://www.videohelp.com/convert#4;41
"Art is making something out of nothing and selling it." - Frank Zappa -
so many frickin options though isnt it about time someone came up with a single program to do the lot ?
tht would be sweet -
Originally Posted by Mint"Art is making something out of nothing and selling it." - Frank Zappa
For a single program to do the framerate conversions and encoding, you might try ConvertXToDVD. I use it for PAL Xvids to NTSC DVDs and it does fairly well. If you need better menus, those can always be added later.
Almost sounds like a BFF/TFF issue. Mint- You should post a short (20sec) clip of the Original AVI - one of the problematic areas.
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 08:40 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
