I have built a dvd menu structure in DVDAS 4.
When I enter the main menu i want to play an audio clip, but if i navigate away from the main menu and then back again, i dont want the audio clip to play.
I have done this using multiple main menus ie: one with audio and one without, so i navigate to the one without after the first play. Is this the only way of doing this, or is there a better way?
As I understand it, if I use a loop point, the buttons wont work until the loop point is reached, and i dont want this to happen.
thanks.
In DLP I would use multiple cells, and have buttons active in both, but return to the second cell after leaving the first. Effort wise it is only slightly less than creating two separate menus, but the switch between them is seamless if the first menu if left to run out.
If DVDA doesn't allow buttons before the loop point then you don't have the same luxury, and will have to settle for two menus.Read my blog here.
Anything Sony DVD Architect won't do that Pinnacle Studio will?
By brassplyer in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2011, 00:38 -
Sony Vegas Movie Studio HD 10/DVD Architect 5, recompress for blu ray?
By apollo1980 in forum Authoring (Blu-ray)Replies: 5Last Post: 27th Mar 2011, 17:01 -
DVD Menu Studio export to DVD Architect
By sir_rob in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 18:18 -
Menu transitions/effects with Sony DVD Architect Studio
By sir_rob in forum Authoring (DVD)Replies: 9Last Post: 25th Jul 2008, 19:24 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14
