Firstly, I have just built my new computer based on an Intel e6600 Core 2 Duo Cuo 2.4ghz overclocked to 3.6ghz, so speed is absolutely not an issue here.
I will be using Adobe Premiere 2.0 as my main editing software.
My plan is to use my sony dv camcorder as a pass through device, connected to my tape player. Once the DV file has been transferred to my computer, then I will begin editing.
What I am looking for is some good video noise reduction as the tape is over 20 years old. Is neat video the best out there? Is there anything else I could do to improve my workflow?
You don't think posting a screen cap of an example of the video noise might be helpful?
I ran it through the rude filter and fixed it.Originally Posted by Soopafresh
This is one of the better recent discussions on the topic : https://forum.videohelp.com/viewtopic.php?t=309181
For the most part it talks about avisynth filters and the various pro, cons and combinations. Well worth a read.
I have used Neat, and some of what it does is good, although like any noise reduction tool it is easy to start taking out details as well. It is also incredibly slow for what it does. There are combinations of avisynth filters (PeachSmoother, Convolution3D, VagueDenoiser etc) that can do an equal, and in some cases better, job as Neat, and will do it5 times faster (or more).Read my blog here.
Converting from tape to DVD
By oldgrumpy in forum Newbie / General discussionsReplies: 7Last Post: 21st Dec 2011, 14:39 -
Estimate for converting a 2 inch video tape
By davexnet in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2011, 18:17 -
Problem converting from digital8 PAL tape to NTSC DVD recorder
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 27th Jul 2011, 19:01 -
Converting DV tape to divx for a dvd of avis
By clawg in forum Video ConversionReplies: 1Last Post: 8th Apr 2008, 12:59 -
iMovie converting 16:9 DV-AVI and DV Tape to 4:3 *.dv files.
By Cyrax9 in forum MacReplies: 4Last Post: 20th May 2007, 04:41
