I authored a certain dvd. the problem is the audio is very weak. Is there a program that i can use to reencode(audio only) this dvd/vob files? i'm using ac3 audio for this. what options do i have to solve this problem and what are the best programs i can use?
pls help! thanks in advance.
Tnx Soopafresh. i alreadt read that thread before. however, i'm looking for a much simler solution. something that wouldn't require me to demux my audio. any suggestions?
I know what you're saying. It is a pain to demux and remux.
There's also Vobdnorm by Coises
ftp://ftp.coises.com/vobdnorm-1.0.zip
Vobdnorm input.vob output.vob 31
Vondnorm will help in some cases, but it isn't designed to be a huge volume boost. It depends on your source.
odd problem: vid looks fine in vegas and AE but weak after rendering. ?
By tsimmons in forum Newbie / General discussionsReplies: 48Last Post: 28th Jun 2010, 06:13 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
My new Harddrive didnīt work, to weak computer?
By Espen in forum ComputerReplies: 6Last Post: 24th Sep 2008, 14:47 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
