I have download some rar, r0........ files. I use those .p0..... files to check those rar files. All files are good. But we I use WinACE and WinRAR to joint those files, both softwares report the r00 files had problem. WinACE only came out a rejointed file with 20 some MB shot. Is there any way to fix those files?
Thank you
open winrar and navigate to the file that is giving you a problem. right click on the file and select repair archive. follow the directions and make a new file. your new file will be called recovery.rar or something like that. once you have the recovery file just move the bad file out of the directory and change the name of the recovery file to match the bad file and put that into the folder with the rest of the archive. now extract and you should have a working archive that can fully extract.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
files .rar
By marlo in forum ComputerReplies: 13Last Post: 14th Jun 2009, 05:57 -
.rar files
By deadman1972 in forum ComputerReplies: 10Last Post: 26th Aug 2008, 11:37 -
rar files w no pars
By rotuts in forum MacReplies: 2Last Post: 8th Aug 2008, 22:30 -
How do I burn .rar files and other
By cinemanetwork20 in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2007, 10:48 -
Problem with RAR files
By crowheart in forum Newbie / General discussionsReplies: 16Last Post: 15th May 2007, 00:49
